where do you top up transmission
307,344 MILES • 2.4L • V6 • 2WD • AUTOMATIC
PETER MANA
Would like to add fluid to prevent slipping
Jan 27, 2016 at 12:43 PM
HMAC300
  • 48,601 POSTS
it takes auto trans fluid DIAMOND SP or compatible. if fluid is dark brown or black and smells burnt have a trans guy rebuild it as that is probably the problem. must be between marks on stick for full on a level surface
Jan 27, 2016 at 10:20 PM
