where can I get the timing specs
2003 LAND ROVER FREELANDER
123,000 MILES
PATRICK HENNESSEY
Head gasket went on my vehicle. I took it all apart now I cannot find the specs or procedure on how to set the timing. any help would be great. it is a 20p3, 2.5 v6.
Feb 15, 2017 at 7:12 AM
HMAC300
  • 48,601 POSTS
you will not find any timing specs as it is done by computer. if you have a dist and was pulled then a mechanic has to set the cam/crank sensor synchronization with a scanner.
Feb 15, 2017 at 11:00 PM
