Egine will not turn over
2007 DODGE TRUCK
108,000 MILES
BERT MARTINEZ
Plugged Bullydog programmer into truck and never could establish communication with it. Disconnected programmer and never could get truck to turn over again.
Jun 1, 2016 at 3:46 AM
HMAC300
  • 48,601 POSTS
try resetting security system if it still wont start have a local professional check the connection of aldl and scan for codes for why it wont start. the programmer may have started to program then stopped so it is incomplete and messing with starting up.
Jun 1, 2016 at 5:06 AM
BERT MARTINEZ
No diagnostic tool want to hook up to truck. No fault finding tool will communicate.
Jun 1, 2016 at 5:09 AM
HMAC300
  • 48,601 POSTS
that is why you need to have a professional look at it to see if the connection is bad so he can fix it. you might check fuses under-hood as well as some have a fuse.
Jun 1, 2016 at 5:57 AM
