When starting,starter continues to be engaged
200,000 MILES • 2.9L • V6 • 4WD • MANUAL
KENMILLERSR
Tried everything can think of. Replaced starter, replaced solenoid, pulled switch and cleaned, checked for bad wiring, checked clutch disengage relay switch. Will start normal some times. Tried to start again this morning and starter hung up again. Have to disconnect battery to stop started from running. HELP
Ken
Oct 28, 2014 at 1:18 AM
WRENCHTECH
  • 20,760 POSTS
Had a problem like this on a Ford once before and it turned out to be a body ground that was off in the engine compartment.
Oct 28, 2014 at 5:00 AM
