When i press the gas it doesnt move
AUTOMATIC
SOVEAL
Basically my car starts and i start driving then 5 mins later when i press the gas it just wont move. Then i turn it off then back on and 5 mins later it does the same thing. So the 1 st man told me that it was the fuel filter, so i had that replaced but it did the same exact thing. After that they cut the exhaust pipe off my car thinking it was clogged, but it still was doing the same thing. The other man said it was my throttle actuator but i dont think my car has a throttle actuator. I really need to figure out whats wrong and ASAP please!
Mar 28, 2015 at 6:17 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge 41-47 psi
Mar 28, 2015 at 9:28 AM
SOVEAL
Mkay that helps alot, cause a few months before it started doing that I went over a railroad track to fast and it put a small hole in the side of my gas tank and my friend jb welded it back to normal, do yu think that was the problem?
Mar 28, 2015 at 10:48 AM
HMAC300
  • 48,601 POSTS
hard telling but jb weld is no fix for a gas tank. do what I suggested
Mar 29, 2015 at 12:58 AM
SOVEAL
Ohh I definitely plan on doing that, thanks soooo very much god bless yu!
Mar 29, 2015 at 1:00 AM
