The reason for that is because there is a resistance designed into the gauge so that when you turn corners, hit bumps, fill the tank, the gauge does not wave around like a flag. They changed the gauge design in 2000 so the needle moves a bit faster.
When you should worry is if you fill the tank and it does not go to the full level on the gauge. That is a sending unit failure.
Aug 29, 2017 at 12:50 PM
