when i am driving the car suddenly jerks three times then keeps going, codes P0113 and P0031
136,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MISSLUNA
  • 5 POSTS
It seems to have rough idle when i come to a stop at a red light. the codes the OBD 2 is giving me are P0113 and P0031.
Oct 10, 2019 at 6:53 AM
  • 110,248 POSTS
Welcome to 2CarPros.
The P0031 indicates an issue with the heated oxygen sensor and the P0113 is with the intake air temp sensor. I suspect the O2 sensor may be setting due to the IAT. What needs done is to check both. I would start with the IAT, but the diagnostics require a live data scanner.
I will attach the diagnostics in the pics below. If it is something you can't do at home, please let me know.
Oct 11, 2019 at 11:27 AM
