When I accelerate I hear a slight ticking sound?
94,000 MILES • 3.1L • AUTOMATIC
RICH650
I bought the car and the owner just did an oil change and now when I accelerate I hear a slight ticking sound .. the owner said once I drive it for a few miles it should stop? Is this something I should freak out about? Please help me
Aug 23, 2026 at 3:26 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Check the oil level using the vehicle procedure and confirm the oil and filter fitted during the service. Look for an obvious service-related leak with the engine off. If the oil-pressure warning appears, or the sound becomes a heavy knock, stop the engine and arrange inspection. Have the noise localized before accepting that it will go away. A technician can distinguish an exhaust leak from valve-train, accessory or deeper engine noise and measure oil pressure if indicated. Do not perform a driveway brake-loading test to reproduce it. Checking the recent service and identifying the sound's location are useful first steps. A small exhaust leak may be repairable, but that diagnosis needs confirmation.
Guidance references and applicability
Chevrolet: Engine-oil guidance https://www.chevrolet.com/support/vehicle/under-the-hood/engine-oil General manufacturer guidance on oil-level checks and low-oil-pressure warnings. Use the actual vehicle's manual for oil specification and checking procedure. Walker: Exhaust-system inspection https://www.walkerexhaust.com/support/tech-tips/how-to-perform-exhaust-system-inspection.html General inspection reference for leaks, physical damage and restriction. It does not identify the cause of this vehicle's noise.
Read the replies · Discussion summary and reported outcome
CARADIODOC
  • 34,414 POSTS
If you only hear it under acceleration, a common cause is an exhaust leak, usually where the exhaust pipe is bolted to the manifold. If the noise goes away after the engine is warmed up, it's because the metal parts have expanded and the leak is sealed. That type of leak is more of an annoyance and can change over time. There are mechanical things in engines too that can make clicking sounds, but most can't be heard from inside the car. To get a better idea of the cause, let a mechanic listen to it, then reply back with his assessment.
Aug 23, 2026 at 3:57 PM
RICH650
Is this a must fix or can I still drive until Friday which is payday?
Aug 23, 2026 at 4:05 PM
CARADIODOC
  • 34,414 POSTS
Depends on how easily you become irritated by the noise. Most people ignore it and drive peacefully into the sunset. To say that a different way, it's nothing to get excited about. If it still bothers you, have a mechanic listen to it. You may have to take him on a test drive if that's what it takes to hear the noise. Sometimes you can make an exhaust leak show up by doing a "brake stand". Hold the brakes on firmly, then try to accelerate while in "drive". Quarter throttle is usually enough torque to make exhaust leaks show up.
Aug 23, 2026 at 5:27 PM
Discussion summary
The owner reported a ticking sound under acceleration after purchasing the vehicle and changing its oil. The seller expected it to disappear. A contributor suggested an exhaust leak, but no inspection or confirmed cause was reported.
Reported outcome: No cause or repair was confirmed.
The discussion does not establish that continued driving is harmless or that the ticking is an exhaust leak.
Read the original discussion
