Engine starts fine, but after about 10 min drive will stall at traffic lights or when idling. Removed and checked IAC. Checked when IAC was out with ignition switch ON - OFF. When turned it OFF, the valve and the spring got disconnected from the body, jumped like projectile. Tried to screw it back on - will not go back to where it was. Does that mean that IAC is gone?
Jun 25, 2014 at 1:40 AM
