When hot engine stall at idling.
130,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
STANKO
Engine starts fine, but after about 10 min drive will stall at traffic lights or when idling. Removed and checked IAC. Checked when IAC was out with ignition switch ON - OFF. When turned it OFF, the valve and the spring got disconnected from the body, jumped like projectile. Tried to screw it back on - will not go back to where it was. Does that mean that IAC is gone?
Jun 25, 2014 at 1:40 AM
HMAC300
  • 48,601 POSTS
just replace the iac with another and clean throttle plate on both sides and iac hole with choke cleaner.
Jun 25, 2014 at 2:32 AM
