When engine comes up to temp, engine problems start.
182,000 MILES • 2.7L • 4 CYL • 4WD • AUTOMATIC
TACOTACO22
When I start my truck it runs fine until the oil comes up to running temperature. Then I experience a periodic hard engine shake (every 5-20 seconds) with a slip of power and air sputter noise out the muffler. This has all happened immediately after an oil change. I also sprayed the drive belt with conditioner and hose off my underbody with water to clean any spilled oil.
Aug 1, 2015 at 2:13 AM
CJ MEDEVAC
  • 11,000 POSTS
AND OF COURSE,
IF SOMEONE ELSE DID THE OIL CHANGE, YOU IMMEDIATELY PULLED THE STICK TO INSURE ALL WAS GOOD?
HAVE YOU CHECKED THE OIL LEVEL WITH THIS ISSUE NOW GOING ON?
THE MEDIC
Aug 1, 2015 at 7:53 AM
TACOTACO22
As far as the oil, all seems good. Level good, no leaks. The more research I do the more it sounds like a problem with the distributor...
Aug 3, 2015 at 9:55 AM
CJ MEDEVAC
  • 11,000 POSTS
IS THE CHECK ENGINE LIGHT ON?
THE MEDIC
Aug 3, 2015 at 10:53 AM
TACOTACO22
Yes, but it's been on (O2 sensor) for 5-6 months. Check it for new errors?
Aug 3, 2015 at 6:41 PM
CJ MEDEVAC
  • 11,000 POSTS
ROGER
THERE'S HUNDREDS OF CODES
ONLY ONE LIGHT!
THE MEDIC
Aug 4, 2015 at 10:27 AM
