When driving neutral light is flashing
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
SBONE47
  • 5 POSTS
Check engine light is on and while driving; the neutral light is flashing.
Dec 17, 2018 at 7:11 AM
DANNY L
  • 5,648 POSTS
Hello,I'm Danny,
That means that both engine and transmission codes are stored in your vehicles computer.You need to have the codes checked to have us properly diagnose your vehicle.If you don't have access to a code reader/scanner your local auto parts stores have a tool loaner program and can rent you one.Most stores will check the codes for free. I've attached a tutorial showing what is involve on how to check codes.
Once you have this done and get back to us with the information we can help diagnose your vehicle.Hope this helps and thanks for using 2CarPros.
Danny-
Dec 17, 2018 at 10:15 AM
SBONE47
  • 5 POSTS
Thanks Danny; I will get a reading of the codes and work from that point forward!
Dec 17, 2018 at 4:54 PM
DANNY L
  • 5,648 POSTS
You're welcome!
Keep us updated and thanks again for using 2CarPros.
Danny-
Dec 18, 2018 at 3:49 AM
