I recently swapped my engine does a mechanics change transmission fluid when doing a engine swap?
Oct 28, 2015 at 10:47 AM
CARADIODOC
✓Experienced Mechanic
Nope. The engine has nothing to do with the transmission fluid. It IS customary but not required to change the oil after starting the engine if the history of that oil isn't known.
