Numerous times either after a snow or after washing the car as soon as the temperature falls below 32-30 degrees and the car sits for several hours I unlock the door, get inside and close the door normally and it will not latch closed. Luckily this happened on my driveway at home.
I have sprayed into both the outside lock and the latch numerous times and heavily liquid wrench, spray can lithium grease, spray can dry lube and wd 40. when temperature is over 32 degrees doors latch perfectly. I took a hairdryer on high and hot for thirty seconds half an inch from the door latch and Viola,. When closing the door it latches immediately and smoothly every time. I have had to do this numerous mornings below 32 degrees one Ii figured out that it worked. My fear is I will be at a store or restaurant and not be able to get the door to latch. .Again only when below 32 degrees. Must be moisture accessing from somewhere. My 1993 Camry had the exact same issue. Any ideas how to prevent this in the first place please?. Thank you in advance.
Feb 18, 2019 at 10:11 PM
