when car reached 100000 everything seems to be going wrong
100,000 MILES
LEANNE1234567
hi , my check engine light keeps coming on I had it services and they said it was my gas cap , just as im pulling in my drive way the car jumped a bit and now the engine light is back on . someone said it could be my timing belt is there any signs of that getting bad or does it just break ,also my radio stopped working but I have bough a new one and it seems to be working fine the man that changed the radio said it looked like water was getting in somehow where could it be getting in at any help would be great I don't want to spend too much
Jun 8, 2013 at 4:16 AM
CARADIODOC
  • 34,414 POSTS
The timing belt should have been replaced some time ago. There's only one engine size available for your car and it is an "interference" design. That means when the timing belt breaks the open valves will be hit and bent by the pistons as they coast to a stop. That is a very expensive repair.
There's two things that can happen. Most commonly the timing belt will snap unexpectedly leaving you sitting on the side of the road. Sometimes it will jump a tooth or two first. That is not enough to cause serious damage, . . . yet, but engine power will be seriously lacking. You will definitely notice the lack of performance. Some Engine Computers will shut the engine down to protect the valves but the Check Engine light will turn on and there will be a diagnostic fault code to indicate that. Chrysler products turn the light on when the belt jumps just one tooth because some people won't notice it and they'll keep on driving. They shut the engine down when the belt jumps two teeth. Not all other manufacturers do that. They just assume you will follow the recommended service interval, and they hope the belt won't break before that. Most manufacturers typically recommend the belt be replaced at around 75,000 miles. Honda had that recommendation in the '80s, and the belts typically broke at 65,000 miles leaving a lot of owners very unhappy.
Jun 8, 2013 at 4:44 AM
LEANNE1234567
hi thanks a lot for the info my friend put it on a computer tester and its coming back p2135 so I guess I will be changing the throttle body ,hope it works out
Jun 9, 2013 at 5:28 AM
