When AC is switched on, grinding noise can be heard
196,000 MILES
DANISHSIDDIQUI
  • 5 POSTS
I own a Chevrolet Optra Manual 1.6 L. When I switch on the air conditioner, I can hear a grinding noise coming from somewhere in the engine. On pressing the clutch, I can feel the vibrations. Have got the throttle body replaced on the mechanic's suggestion, but it has not helped.
Jun 30, 2013 at 6:02 AM
SEANGRANT00
  • EXPERT
  • 334 POSTS
Have you had any work done to you air conditioning?
This could be a couple things,
-Your A/C is overcharged
-Your compressor clutch is bad or about to fail
-Condinsation Drain (rare)
-If the noise is closer, blower motor or air door problem
Let me know
Sean
Jun 30, 2013 at 4:13 PM
DANISHSIDDIQUI
  • 5 POSTS
Hi Sean,
Thanks for your prompt reply.
I just bought this from a friend of mine. It's been over 2 months, but, this AC problem was there since the start. Earlier the car would always shut down the moment I would start the AC so I never noticed this noise. For now, the mechanic managed to set the RPM a bit high, so at least it doesn't shut down. However, there is this grinding sound which is a bit scary. I really don't know what to do with it, cos the garage guys are a piece of junk here.
Jun 30, 2013 at 8:26 PM
SEANGRANT00
  • EXPERT
  • 334 POSTS
This could be a couple things, how cold is the air coming out?
It could be a low amount of oil in the system, which is causing more friction. It also could be a bad clutch or compressor. The bearings in the compressor could also be going out. See if you can push on the clutch and see movement or play. This would indicate a bad bearing.
Sean
Jul 1, 2013 at 9:24 AM
DANISHSIDDIQUI
  • 5 POSTS
I can feel the grinding whenever I press the clutch. Looks like i'll have to get the bearings checked.
Jul 1, 2013 at 10:09 PM
DANISHSIDDIQUI
  • 5 POSTS
however, one thing confusing is why does RPM go down the moment AC is switched on?
Jul 2, 2013 at 3:21 AM
SEANGRANT00
  • EXPERT
  • 334 POSTS
Normally any addition of a load to the engine will bring the RPM's down. The computer typically raises the idle to balance this out. In your case, the bearings going out would put a higher load on the engine. When you get this fixed it should go back to normal.
Sean
Jul 2, 2013 at 6:58 AM
DANISHSIDDIQUI
  • 5 POSTS
great ill let you know
Jul 3, 2013 at 3:15 AM
SEANGRANT00
  • EXPERT
  • 334 POSTS
Sounds good
sean
Jul 8, 2013 at 5:11 AM
