Wheels fell off while driving after having the water pump replaced?
10,000 MILES • 2.0L • 4WD • MANUAL
DELLYBIRD1984
Hi, my wheels fell off whilst driving on motorway last Monday the garage change water pump. And Cam belt would the garage of needed to take the wheels off as all bolts where loose?
Sep 17, 2023 at 8:28 PM
  • 55,711 POSTS
Yep! the wheel is removed when doing this job. Please let us know if you need anything else to get the problem fixed.
Sep 18, 2023 at 8:16 AM
DELLYBIRD1984
Okay, it's just they are stating they didn't remove the wheel is this possible to do without wheel removal at all. I've included a picture of the damage.
Sep 18, 2023 at 5:24 PM
  • 55,711 POSTS
I am sorry this happened to you, let me get another expert opinion on this.
Sep 20, 2023 at 10:17 AM
DELLYBIRD1984
Okay, thank you that would be very helpful.
Sep 20, 2023 at 6:26 PM
BORIS K
  • 836 POSTS
While some of the work can be done from the top of the engine past the engine, mounting the lower part of the job requires removal of the right front wheel.
This allows the removal of the wheel arch liner which gives access to the crankshaft pulley.
See good video:
https://youtu.be/poaAtfKW4m8?si=WweGVBIdICKhQH5q
Cheers, Boris
Sep 21, 2023 at 1:24 AM
