Shimmy when driving at high speeds 75 to 80 mph
106,000 MILES • 4.6L • V8 • AUTOMATIC
MROULET1
  • 79 POSTS
That happen about every 4 seconds. So it will ride smooth at first then every 4 to 5 seconds it will happen.
Nov 22, 2019 at 3:24 AM
  • 110,248 POSTS
Does this happen at any other speeds? Have you inspected the tires as well as have tire balance checked? Also, when you feel the shimmy, is it in the steering?
Nov 22, 2019 at 1:38 PM
JIS001
  • 3,412 POSTS
Hi, just wanted to jump in here really quick. If the vibration only happens when you accelerate at those speeds then I would suspect bad axles. When the inner joints start to bind it will cause the vibration and majority of the time it happens only on highway speeds.
Nov 22, 2019 at 2:49 PM
MROULET1
  • 79 POSTS
Yea, it’s in the steering.
Nov 23, 2019 at 3:16 AM
  • 110,248 POSTS
Have you had the tire balance checked? Also, it could be an axle joint starting to go bad. Does it happen regardless if you are accelerating, maintaining speed, coasting, or braking?
Nov 23, 2019 at 9:16 AM
MROULET1
  • 79 POSTS
It just happens at those speeds and the faster I go the worse it gets. I work with tires, I don’t believe it’s a balance issue.
Nov 25, 2019 at 2:50 AM
  • 110,248 POSTS
Okay, then I have to suspect an issue with a steering component or one of the axle joints is going bad. Have you had the chance to check those components? Also, are there any sounds associated that may indicate a bearing issue?
Here are a few links you may find helpful regarding axle joints:
https://www.2carpros.com/articles/how-a-cv-joint-works
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
https://www.2carpros.com/articles/replace-cv-axle
Nov 25, 2019 at 10:27 AM
MROULET1
  • 79 POSTS
Just want to thank you for the help. It was just tires. Just put them on yesterday and it rides like a Cadillac!
Nov 30, 2019 at 12:24 AM
