Wheels swap
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
MACKERMAN84
Will 2008 Nissan Quest wheels work on a 2016 Nissan Quest? Want cheap wheels for snow tires.
Aug 16, 2019 at 11:14 AM
SCGRANTURISMO
  • 4,897 POSTS
The best way to tell is to see if the lug pattern matches up. After that this is how you read tire sizes. Almost every passenger car will have tires that start with a P, the only variant of this will be the LT variant, which stands for Light Truck. Next is the number for the width of the tire in millimeters, next is the number for the aspect ratio(the height of the tire from the top of the rim to the top of the tire), and finally the rim size. So here is an example of the tire size on my vehicle. P245/45R17. Please get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Aug 16, 2019 at 7:11 PM
