Wheel hub /axle the steering wheel is jerking grinding?
185,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
JKOL
Where what I believe is the axle goes into the inside of the wheel hub assembly the mount where the axle goes into the wheel hub assembly the metal is being shaved away and the wheel is jerking grinding.
Sep 30, 2024 at 8:12 AM
  • 55,688 POSTS
Yep, the bearing hub is going bad. I would recommend watching this video so you can change them out, I would do both sides, the job is not that bad to do, and you can save money by doing it yourself. Also, I would not drive the car until the repairs are made.
https://youtu.be/qOAyXfPo7Z0?si=3WpJR9B_4DFbnHKX
The process is the same in the video. Please upload pictures or videos in your response of any problems so we can see what to help you with.
Oct 1, 2024 at 4:36 AM
