Wheel studs keep breaking
76,800 MILES • 5.4L • V8 • 2WD • AUTOMATIC
JAEDAV12
  • 46 POSTS
So today I have run into an issue I had a month ago and that involved my rear tire rolling down the street. The first time it happened was simply because of the fact the wrong size lug nuts were put on so they stripped out. Got the studs replaced and today noticed one of the studs snapped so on the way home the wheel came off and all the studs snapped off. I have a set of Fuel Hostage 20x9 time on the truck with a set of 33x12.5R20 tires. Do I need bigger studs to support the weight of the wheel or am I over/under torquing the lug nuts down ? These are a set of universal rims also.
Apr 1, 2020 at 9:01 AM
This should not require larger studs. I suspect this is one of two issues. First if the studs are actually breaking off then I suspect you are over torquing the lug nuts which is stretching and compromising the stud. The other possible cause is under torquing which allows the wheel to move slightly and it actually vibrates the lugs loose and the wheel eventually falls off. However, before this happens it normally makes some noise.
Here are the torque specs for tightening the lugs. I would replace the lugs again and then inspect all the others to make sure they are not stripped and then torque them to the proper spec.
Let me know if this make sense. Thanks
Apr 1, 2020 at 9:47 AM
JAEDAV12
  • 46 POSTS
Thanks I’ll try that and would wheel fitment be a possible issue?
Apr 1, 2020 at 10:05 AM
CARADIODOC
  • 34,415 POSTS
The first issue is the need for using a click-type torque wrench. It sounds like you have that covered. Most do-it-yourselfers, and even some experienced mechanics aren't aware of the importance. That includes a friend of mine with a body shop where he specializes in rebuilding one and two-year-old smashed Dodge trucks. He lost a pair of his rear duallies when I was on a short trip with him, and he still refuses to use his over-priced Snapon torque wrench. The only wheels that ever get torqued in his shop are those in there when I'm killing time helping him.
Ford's torque specs for your wheels have a rather broad range of 83 to 112 foot pounds. I wouldn't go much higher than 100 - 105 foot pounds with cast wheels. 110 foot pounds should be good for steel wheels.
Let me interject a side note here, especially for the benefit of others who might be researching this topic. It's fairly common to find damaged studs and lug nuts when removing a wheel, either for rotation, replacement, or when doing a brake system inspection. Sometimes we have to cut the nut off because it is just spinning, and that often results in damage to the wheel. Naturally, you, as the person working on the vehicle, gets the blame from the owner for causing that damage, but it's important to understand that damage was done by the previous person who installed that wheel, when they over-tightened the lug nuts. Very often that is the owner himself. You have to explain to the owner that lug nuts do not become damaged by removing them. They develop peeled threads from over-tightening, and that was done at the last service.
As for the size of the studs, that is not an issue of the wheel's weight. That's a factor related to the weight of the truck. Cast wheels are used to reduce weight for better fuel mileage, but the studs are designed to be used with steel or cast wheels.
The first consideration is when installing cast wheels, and after replacing the studs, the torque should checked again after about 50 - 100 miles. New studs might not have pulled all the way in yet. Cast wheels are relatively soft, and any deformity in the friction area or small chips of dirt or debris will rub away leaving the nut insufficiently tightened.
Next, if you have aftermarket wheels, most of them are designed to fit many models with the same bolt spacing. To achieve that, the center hole has to be large enough so the wheel will fit on all those models. Fords especially use original wheels that fit very tightly on the hub, often to the point a 20-pound mall is needed to remove the wheel. Lug nuts and studs are not designed to hold up the weight of the vehicle. That is the job of that center hole in the wheel. When the hole is larger than the hub, it falls on the studs to do that. The constant up and down forces on the wheel are going to work the nuts loose. The nuts are only supposed to hold the wheel to the hub. They're not meant to hold up the vehicle's weight.
The rest of the issues have to do with the studs and wheel themselves. Once a wheel has fallen off, regardless of the cause, it is almost a certainty the curved friction surface where the nut contacts the wheel will be chewed up or deformed. The shape of those surfaces are critical that they match. It's that tiny patch where the friction is all that holds the nuts tight. Once a wheel or lug nut has been deformed, they have to be replaced as they will never remain tight with that damage.
Related to that is the use of grease on the studs. First, most import vehicles use "anodized" studs. Those have a light yellow, light green, light blue, or silver color. That anodized coating is a lubricant in itself and no grease of any kind is supposed to be used on them. Some greases will melt that coating resulting in the threads peeling when you try to remove the nuts, even when they were tightened properly the last time. When you do use grease on non-anodized studs, use just a very light coating to prevent rust. Many people think if some is good, more must be better, but that is not the case. The problem develops when you use an air impact wrench to run the nuts on, even though you stop short, then finish the job with the torque wrench. That wad of grease builds up ahead of the nut, then centrifugal force flings it out onto the wheel. There it gets caught on the friction surface and prevents the nut from holding on. If you do use a little grease, run the nuts on by hand, then torque them.
Also be aware to never ever use any type of anti-seize compound on the studs. That is serious enough that you might get one verbal warning, but at most shops you'll be fired instantly. I did allow my students to use that around the center hole since we're in a state where they throw a pound of salt on an ounce of snow, and rust is common, but never on the studs. Since you're a mechanic, you might appreciate my story from when I was the suspension and alignment specialist at a very nice family-owned Chrysler dealership. Since I was back-logged with other jobs, a coworker installed a pair of front struts on a Dodge Dynasty, and being the conscientious fellow he was, he coated everything with anti-seize compound to prevent a rust problem that never actually occurred. Unlike other Chrysler models that used "cam bolts" to make alignment adjustments easier, these just relied on the clamping forces of two really fat bolts to hold the wheel in alignment. They hold the wheel so well, hitting pot holes at high speed rarely causes them to slip. In this case, when he sent the car to me for the alignment, both front wheels had tipped in on top as far as they could go. I jacked it up, pulled the wheels out, tightened the bolts, let the car down on the tires, and the wheels immediately slipped again. That was frustrating enough but then the same thing happened a second time. The third time they slipped, I was frustrated with myself, thinking I wasn't tightening those bolts enough, I really cranked them down, so much so, that I snapped one of them apart right in the middle. I'm a little guy, but I pulled a bolt apart that was 3/4" in diameter, with a 1/2" ratchet. Once I took the wheel off to see what was going on, I found the anti-seize compound slobbered all over. That all had to be washed off for the alignment to hold. Even using axle grease doesn't result in that problem, so it shows how serious it would be to use it on wheel studs. No shop owner wants to risk the liability or lawsuits. That's why the offender usually gets invited to look for a job somewhere else.
Here's a link to a related article:
https://www.2carpros.com/articles/wheel-removal-and-re-installation
You probably have had this training already, but it's good reading for anyone else doing this job at home.
Apr 1, 2020 at 10:06 AM
JAEDAV12
  • 46 POSTS
Thanks cardiodoc! I never put anti-seize on stub usually just a medium strength loctite for safety but I’ll have to try greasing the new studs this go round !
Apr 1, 2020 at 10:13 AM
Just to jump back in. You don't want to put anything on the studs like oil, grease, anti seize. The lugs can rust but you just simply brush it off with a wiring brush. If they are bad enough then you replace them. Take a look at the guide that Cariodoc provided (screen shot below).
When you add this to the stud, it actually changes the torque force because it lubricates the threads and allows it to turn more as the friction on the stud to lug is less and you can over torque them again and compromise the stud.
Apr 1, 2020 at 10:23 AM
JAEDAV12
  • 46 POSTS
Ah, I see. thank you both for the information!
Apr 1, 2020 at 10:26 AM
You are very welcome. Please come back if you need more assistance and let us know how you make out when this is completed. Thanks
Apr 1, 2020 at 10:28 AM
CARADIODOC
  • 34,415 POSTS
I've been teaching this for many years, but it never occurred to me the risk of over-torquing due to grease on the studs. Thanks for bringing that up. Similarly, what about rust on the studs resulting in insufficient tightness? Does that become a concern, and would a little grease overcome that?
Apr 2, 2020 at 4:32 AM
JAEDAV12
  • 46 POSTS
So I replaced the studs torqued them all down to 100ft/lb as Ford states. One question. Considering my rim and tire set or significantly larger than stock would I be better off converting to a M14x2.0 wheel stud or will the stock M12x1.75 do fine ?
Apr 4, 2020 at 4:28 AM
CARADIODOC
  • 34,415 POSTS
The studs are a product of the vehicle's weight, not the wheel size. That's why some trucks have six or eight studs even though their wheels don't weight much more than those with five studs.
The exception to this is if you have aftermarket cast wheels that are significantly thicker around the holes than the originals were. That would reduce the number of threads the nuts would cover. In that case you's need longer studs, not fatter ones. That would have been specified by the wheel manufacturer or the person who sold them to you.
Apr 4, 2020 at 7:39 AM
JAEDAV12
  • 46 POSTS
Thanks a lot. I didn’t even think of it like that. I’m just so confused on what went wrong I had the studs professionally installed and I did tighten the lugs but I know it was more than 100ft/lbs.
Apr 4, 2020 at 7:43 AM
