Wheel spindle replacement part
183,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
CANNON1349
  • 861 POSTS
The inner bearing inside the rotor exploded, and the entire spindle assembly got so hot the spindle nut welded itself to the threads. Will have to take a puller to the rotor to get it off. But, I have to be able to replace the spindle portion and I see nothing online, just entire steering knuckles. There is no CV axle there because it is RWD. Behind the spindle there is a huge hex indention, as if it was made to be serviceable.
Aug 27, 2019 at 4:03 AM
Unfortunately, these are not servicable separate that I am aware of. There is no process in service manual for this either. In fact, I have replaced a ton of knuckles on these and they always come with the spindle.
I think the nut you are seeing is for manufacturing purposes only.
Sorry to not have better news.
Aug 27, 2019 at 10:16 AM
