Wheel movement
141,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
INTOSILENCE1
  • 79 POSTS
When I was tightening the lug nuts, I could make the wheel move quite a bit with the breaker bar. Is this normal, or what could be the cause?
Nov 1, 2020 at 3:09 AM
Does the vehicle drive okay? If so, I suspect that is the movement from the suspension and steering system.
You could have some slack in the tie rods or even a little in the wheel bearing/hub. No matter what, I would suggest putting the front wheels on jack stands and shacking down the front wheels. You do this by putting your hands on the tire at 3 and 9 o'clock as if it were a clock and push and pull with opposite hands. There should be no loose feeling and this is checking the tie rods. Then do the same at 12 and 6 o'clock to check the upper and lower ball joints.
If these are tight then it is normal. Thanks for getting the video. That really helped.
Nov 1, 2020 at 5:09 AM
Good afternoon
No, that is not normal. You have an issue there.
https://www.2carpros.com/articles/popping-noise
You need to check the ball joints as well as the control arms for movement.
https://www.2carpros.com/articles/how-to-release-a-ball-joint
You need someone to do what you are doing and you go under with a bright flash light and look for the movement.
I attached a blow up of the suspension for you and circled the common areas of wear.
Nov 1, 2020 at 5:12 AM
