The lugs stripped out on the back side of the wheel hub assembly. What is the trick to removing the wheel to replace the assembly?
Dec 7, 2018 at 9:43 AM
✓ASE Certified Mechanic
Good afternoon,
The post is confusing. What is stripped? The lug nuts or the bolts holding the hub attached to the spindle?
Can you post a picture of what you see?
Dec 7, 2018 at 2:36 PM
MARK8474
MEMBER
The lugs themselves where they are pressed into the hub. I cannot pull the wheel off because when I put the socket on the hole thing spins. It is sitting in the shop work and I am two counties over. I will get a picture when I get back.
Dec 7, 2018 at 2:49 PM
Okay, then you have to cut off the lug nuts.
You can either burn them off or use a hole saw and drill them off. It will take a while either way. Then you need to replace the studs and nuts on the hub.
Dec 7, 2018 at 2:52 PM
MARK8474
MEMBER
Thanks! I will keep you posted.
Dec 7, 2018 at 2:55 PM
Sounds like a plan.
Dec 7, 2018 at 3:00 PM
