Wheel hub assembly replacement
468,000 MILES • 2.0L • 4 CYL • AWD • MANUAL
JAYICUS
Hi, I need to replace the wheel hub assembly on my crv and was just wondering what I need to know about the process, what tools I need, important tips etc.
Cheers.
Jan 26, 2016 at 9:58 AM
PACO8224
  • 117 POSTS
Do you own a air compressor it makes the job easier to do. You will need a pry bar, some impac sockets if you have compressor with air gun. If not you will need a breaker bar. Make sure to be very careful not to cross thread cv joint axel nut. And a fork tool to remove ball joints, and a moll hammer
Jan 26, 2016 at 10:19 AM
