wheel hub socket size needed
2002 GMC YUKON
170,000 MILES • 6.0L • V8 • AWD • AUTOMATIC
DU MARCE JOYCE
Size socket needed.
Dec 22, 2016 at 3:17 AM
HMAC300
  • 48,601 POSTS
measure it may be a 36/40 mm socket for axle shaft .
Dec 22, 2016 at 3:52 AM
DU MARCE JOYCE
Wheel hub bearing assembly size socket needed.
Dec 22, 2016 at 4:03 AM
HMAC300
  • 48,601 POSTS
for the one to remove axle it is either a 34 or 36mm for the ones marked in picture are either 15mm or 18mm I forgot on the axle bolt.
Dec 22, 2016 at 5:15 AM
