Wheel removal
1994 FORD EXPLORER
117,000 MILES • 6 CYL • 4WD • AUTOMATIC
JAMES DINVERNO
1 lug nut won't come off. Is there a key?
Nov 13, 2019 at 1:28 AM
Good afternoon,
Can you post a picture of the lug nut? I need to see what you see?
Nov 13, 2019 at 4:41 AM
SCGRANTURISMO
  • 4,897 POSTS
You will be able to tell if the lug nut has a key for it or not because it will be shaped differently from the other ones. To my knowledge, I don't believe that Ford Motor Company uses keyed lug nuts with their vehicle's, so if it is a keyed lug nut, it is more than likely that it is an aftermarket add on. You will have to figure out the manufacturer and go about getting a key that way, or cutting the lug nut and stud off with a rotary tool and punch the rest of the stud back through the rotor and replace them. I hope that this helps.
Thanks,
Alex
2CarPros
Nov 13, 2019 at 4:42 AM
