wheel cylinder
222,000 MILES • 3.9L • V6 • AUTOMATIC
JLK1970
I had a wheel cylinder go bad & startef leaking so i replaced it & now it started leaking again the same day i was wondering what is causing it go keep going bad
Apr 5, 2017 at 11:05 AM
CJ MEDEVAC
  • 11,000 POSTS
Are your brakes parts assembled correctly? You have the 'short shoe lining' (primary) toward the front of the vehicle/ the 'long shoe lining' (secondary) towards the rear of the vehicle. (you DON'T have 2 shorts on one side and 2 longs on the other side!- There should be one of each on each side!) Pic below shows a short and long lining on one side, even way back in 1946!
Did you disassemble or push on the cylinder's pistons and make the gut's jump out while installing it?
Are the shoes adjusted outward enough to where the drum will sorta 'barely' go over them (BUT NOT ACTUALLY CONTACTING THE SHOES) In other words, much more adjusting would make the shoes start scraping the drum.
If the shoes were too far inward, the innards of the wheel cylinders would have to "Over-extend" (travel a long way) in order to push the shoes against the drum.
This over-extension may make the seals inside the cylinder push past it's smooth machined bore. When the shoes are adjusted outward correctly, the guts of the wheel cylinders barely move to make the shoes contact the drum.
If you installed a rebuild kit (instead of a new unit) The bore of the old re-used cylinder needs to be honed with a wheel cylinder hone to remove any pitting/ rust/ buildup in the bore. You must insure the kit is the right size for the size bore you have.
Lemme know if this info helps,
I happen to have a few pics (9) of me "cheaping out" with 'rebuild kits'/ honing for my 1946 Willys Jeep wheel cylinders. These are real simple brakes with 'manual' cam adjusters for shoe adjustment (there are no automatic adjusters!)
The Medic
Apr 5, 2017 at 12:08 PM
CARADIODOC
  • 34,413 POSTS
Was that a new or used wheel cylinder you installed? Check if the parking brake cable is rusted in the partially-applied position. Both brake shoes must come to rest on the large anchor pin on top of the backing plate. Also look at the parking brake strut bar between the two shoes. You must be able to push that forward about 1/8" against the anti-rattle spring pressure, by hand. If either of those are not true, the pistons in the wheel cylinder will have to travel too far.
Also be aware most wheel cylinders are assembled with "Brake Assembly Fluid", which is a thick brake fluid. If all you're seeing is wetness when you peel back the dust boot, you may be just seeing that assembly fluid.
Check too that you aren't seeing gear lube from a leaking axle seal. That will be very sticky compared to brake fluid.
One of the biggest causes of repeat misery is when a hint of petroleum product finds its way into the brake fluid. If engine oil, power steering fluid, or transmission fluid is poured into the master cylinder, the first problem will be a high and hard brake pedal, and severely dragging brakes. The only proper repair for that is to remove every part that contains rubber parts that contact brake fluid, flush and dry all the steel lines, then install all new rubber parts. That includes the master cylinder, calipers, wheel cylinders, rubber flex hoses, combination valve, rear height-sensing valve, rubber bladder seal under the reservoir cap, and if the truck has anti-lock brakes, the hydraulic controller or the dump valve assembly. Needless to say, that is a very expensive repair. If any rubber part is overlooked, the contamination will leach out of it and recontaminate the new brake fluid.
The concern around a wheel cylinder is if penetrating oil was used to get a rusted line nut loose. Once removed, if that oil is washed off right away with Brake Cleaner, there should be no problem, but to be safe, I never allow any petroleum-based chemicals near my brake jobs.
One clue to fluid contamination is the problem takes about a week to show up. Rubber o-rings and lip seals grow and become soft and mushy. At first they just stick, but eventually they lose their ability to seal. If that occurs in the master cylinder, the seals grow past the fluid return ports and prevents the pressurized fluid from returning to the reservoir. That is what causes the brakes to self-apply, get hot, then apply harder and harder.
Years ago it was common practice to rebuild wheel cylinders as part of the brake job. That is real easy to do, and only takes a few minutes, but you must inspect the bore along the bottom, right in the middle, for signs of corrosion. If you see that, the lip seals can't seal over that corroded area, and you'll have a leak. That leak often shows up after a do-it-yourselfer simply throws on a new pair of shoes. If the return springs are weak, a parking brake cable was sticking, or in some cases, the design of the self-adjusting mechanism is such that it holds the tops of the shoes out a little, the seals can be running in a clean part of the bore. Installing new shoes and / or repairing other issues can place the shoes back where they should be when at rest, and that can put the seals over the corroded area.
If nothing pans out so far, wash the brake fluid off and dry the area, then watch for where the leaking fluid shows up first. A more likely cause is the line is leaking where it attaches to the wheel cylinder. There can be a hairline crack in the double flare. The flare can be too compressed to seal against the seat, or there can be dirt or rust built up in the threads of the nut making it appear to be tight before it has run the flare up to the seat. The clue is you'll see the wetness on the back side of the backing plate, and it will run down from there. It is common for it to run into the front of the backing plate too, right under the wheel cylinder. If the seals in the wheel cylinder are really leaking, the line and nut will be dry. Usually that area of the backing plate will be dry too. The fluid will drip straight down onto the shoes and drum.
If necessary, give me the history leading up to this, and any observations or clues you can.
Apr 5, 2017 at 12:28 PM
CARADIODOC
  • 34,413 POSTS
Hi CJ. Good thought about the cylinder flying apart. I thought about the spring missing, but didn't think to consider that a suspect with a new wheel cylinder.
Apr 5, 2017 at 12:34 PM
CJ MEDEVAC
  • 11,000 POSTS
Doc,
I'm guilty (a long time ago!) of over-thinking of which direction the inner rubber seals lips went back into the cylinder, after the assembly flew apart while pushing on a piston too much. They just won't hold back brake juice when they are in backwards!
I'm glad you pipe in behind me with other possibilities!
We're gonna have to start wagering on whose suggestions actually fix that particular problem!
JLK1970 need some news, Doc may owe me lunch!
The Medic
Apr 5, 2017 at 12:45 PM
