Wheel bearings are making noise
150,000 MILES • 4.2L
ISTRE
Front wheel bearings are starting to make noise. Can I just replace the bearings or do I have to replace the rotor and all as one unit? Thank you.
Aug 6, 2019 at 10:16 PM
Good morning,
The wheel bearing is serviced with the hub. I attached a picture of the hub with the bearing from rock auto. It is about $85.00.
https://www.2carpros.com/articles/how-to-replace-front-wheel-bearings-and-seals
Why did you think you needed to replace the rotor as well?
Aug 6, 2019 at 11:38 PM
ISTRE
Appreciate the response. Was told by some people that I would have to buy the rotor because it was 1 assembly. Others said I could just by the bearings.
Now, I know who knows what!
Aug 8, 2019 at 2:59 AM
You are welcome.
Aug 8, 2019 at 8:17 PM
