Wheel bearing vs ball joint?
142,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
noticed noise from front suspension after I bought this one. Driving it in my driveway there is suspension noise for sure. The left tire is gone, i noticed some play at the 12/6 movement, how do i know if it's a ball joint or a wheel bearing?
Dec 2, 2023 at 4:15 AM
  • 110,248 POSTS
Have a helper watch the ball joints while you wiggle the wheel. If there is a ball joint issue, you should see it.
Also, if the tire is bad and it appears to be an alignment related issue, a ball joint is the likely cause.
Let me know what you find or if you have other questions. Also, if you could take a couple of pictures of the tire and upload it for me to see, it should help.
Dec 2, 2023 at 12:03 PM
