Wheel bearing replacement
185,000 MILES • 3.4L • 6 CYL • AUTOMATIC
RAUL VASQUEZ
Everything from bolts to the hub bearing are stuck. they have so much rust build on that not only am I having a hard time with the bolts but the bearing is also stuck. I haven't been able to get them off and is stressing. Can someone give me a trick to take them off please?
Mar 8, 2020 at 4:30 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, rust can always be a pain to deal with. Here is the WD-40 Penetrant I like to use.. You might also want to try using a MAP gas style torch to heat up.. Hope this helps and thanks for using 2CarPros.
Mar 8, 2020 at 7:53 AM
  • 55,691 POSTS
Here is how the job is done correctly in the diagrams below. Please let us know if you need anything else to get the problem fixed.
Mar 9, 2020 at 7:20 AM
