Wheel bearing hub removal
146,780 MILES • 4 CYL • 2WD • AUTOMATIC
TREY.MCCOY6
Can you remove your hub assembly without a three jaw puller?
Sep 20, 2018 at 1:05 AM
Good morning.
Yes you can. They recommend using it to push the axle stub through the hub but in most cases, you can push them out using a rubber mallet.
Could you verify your year and model? Is it US?
There should be attaching bolts behind the hub to release it from the spindle as well.
https://www.2carpros.com/articles/bearing-hub-replacement
Sep 20, 2018 at 1:35 AM
Good morning.
Okay, that is better.
I attached the procedure and picture for you to view.
The simple answer is no, you do not need the puller. Just a rubber mallet to release the axle shaft.
Sep 20, 2018 at 8:14 AM (Merged)
