Wheel Bearing Hiccup
85,000 MILES • 2.5L • 4 CYL • FWD • AUTOMATIC
SPENCERASSIFF
Hey, I am replacing my wheel bearing. Axel nut is spinning the bearing when I try to remove it. I want to put the tire back one and lower it to prevent spinning. Can I do this without replacing the whole brake system?
Aug 30, 2017 at 4:07 AM
STEVE W.
  • 15,418 POSTS
Okay, so you are trying to remove the axle nut. You can break it loose by setting it on the ground , but do not tighten it to the torque spec in the same way.
I take it you have already removed all the brake parts? If that is the case just slip the brake rotor on and put a screwdriver or bar into the vents and use it to stop the spinning.
Aug 30, 2017 at 7:51 AM
