Wheel bearing replacement part
2006 RENAULT CLIO
100,000 MILES • 1.4L • 2WD • MANUAL
DECLAN BAIRD
I require a new wheel bearing for my rear axle, however on my vehicle I have non standard alloys that are larger than standard. Therefore I'm struggling to source the part as all the parts shops only seem to suggest the correct wheel bearing for standard alloys on the vehicle listed above
Jun 19, 2020 at 5:23 AM
Unfortunately, we don't have a manual on your vehicle because it is not sold here in the USA. However, if these are factory installed components then you need to look the part up via the VIN. The only way that I know how to do that is by the dealer. Do you have a local Renault dealer that can look this part up? Even if you just get the part number and then you can source the part from others if you don't want to buy it from them.
Let us know what you find and we can go from there. Thanks
Jun 19, 2020 at 9:39 AM
