wheel bearing
90,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
MICHAEL FINK
I took my car to get brake pads they told me when l bearing was bad. I do not hear any grinding. My question is can I drive it at all? I need to drive it to a pier about thirty miles away to ship it, then when i pick it up very short drive to shop to get it fixed. I cannot afford to fix it before I ship it. Will this be okay to do?
Jan 20, 2017 at 4:02 AM
HMAC300
  • 48,601 POSTS
it you do not have any play in it drive it. whatever side it is on drive in a circle the opposite direction if it makes a ton of noise then you will have to fix it.
Jan 20, 2017 at 4:19 AM
MICHAEL FINK
i do not feel play in it out the mechanic said it had play in it.
Jan 20, 2017 at 5:19 AM
HMAC300
  • 48,601 POSTS
you should be ok for thirty miles.
Jan 20, 2017 at 7:17 AM
