When turning right sharply there is a whining and grinding noise
133 MILES • V8 • 4WD • AUTOMATIC
IMAJESTY
  • 6 POSTS
Vehicle makes whining and grinding noise when making sharp left turns.
Oct 15, 2019 at 11:30 PM
SCGRANTURISMO
  • 4,897 POSTS
This could be a wheel bearing. Does your vehicle exhibit any kind of wobble as you drive it, especially starting at a certain speed?
Thanks,
Alex
2CarPros
Oct 16, 2019 at 12:40 AM
IMAJESTY
  • 6 POSTS
No just the grinding , whining noise.
Oct 16, 2019 at 1:30 AM
IMAJESTY
  • 6 POSTS
Oops, my wife said it did when she drove it.
Oct 16, 2019 at 1:31 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Here is a link for you to go to that explains what could possibly be going on with your vehicle below:
https://www.2carpros.com/articles/vehicle-grinding-noise
Please go through this guide and get back to us with what you are able to find out. We can go from there.
Thanks,
Alex
2CarPros
Oct 16, 2019 at 1:35 AM
IMAJESTY
  • 6 POSTS
So both sides should be fixed?
Oct 16, 2019 at 1:40 AM
SCGRANTURISMO
  • 4,897 POSTS
I am not sure what you are referring to, but it is a good general rule to replace things on a vehicle in sets like a set of spark plugs, or both wheel bearings, or both mufflers, a set of tires, so I am going to recommend that you replace both sides. Please get back to us with how everything turns out.
Thanks,
Alex
2CarPros
Oct 16, 2019 at 2:12 AM
IMAJESTY
  • 6 POSTS
Hello. Good morning.
Can you provide the part number for wheel bearings for my 2013 Nissan Armada sv?
Oct 17, 2019 at 12:24 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
I have included the information that you requested in the diagrams down below. Also, have you checked the level of your vehicle's power steering fluid to make sure it's okay?
Thanks,
Alex
2CarPros
Oct 17, 2019 at 6:33 AM
