Wheel and tire size change
2018 DODGE CHALLENGER
10,700 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
BKRIS23
Would 245/30z/r22 fit on the car listed above SXT without any modifications or In general. Also, will it affect the driving ability?
Feb 21, 2021 at 1:15 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
What is the original tire size? When changing tire size, it isn't just the tire. If you are using the same wheels, will they properly fit? Also, if you are changing the wheel size, you have to take into consideration off set. Offset is how far in toward the vehicle or out away from the tire the wheel positions the tire. If it's too far out, it will hit the fender. If it's too far in, it will likely rub the strut, inner fender, or other components.
Here is what I suggest. Go to this site and compare the oem tire size to the ones you want to install. See how much of a difference there is.
https://tiresize.com/comparison/
If you are changing the wheels as well, if they are not from the same type of vehicle, you have to compare offset. Here is a link that I found to be very informative:
https://www.wheelfire.com/blog/what-wheel-offset-do-i-need/
Take care and God Bless,
Feb 21, 2021 at 6:02 PM
