Wheels squeal when turning
117,111 MILES • V6 • 2WD • AUTOMATIC
ARMONDOGREEN
When i turn a corner my tiers squeal like i'm speeding.
Jul 14, 2021 at 4:23 AM
COLBY_STEPHENSON2000
  • 32 POSTS
One quick thing you can try is checking your air pressure in your tires. Low air pressure can do this. Here is a guide that will help with this:
https://www.2carpros.com/articles/how-to-use-a-tire-pressure-gauge
Also we need to check for wear using this guide and the chart attached below:
https://www.2carpros.com/articles/how-car-tires-work
If that doesn't work then possibly alignment out of specific. You would need to take it to a shop for that as they would need to use an alignment machine.
Let my know if you have any questions.
Thanks,
Colby
Jul 14, 2021 at 11:40 AM
