If some wheel lug nuts are torqued and two are gun tight what will happen?
13,009 MILES
YOMESSSI
if some wheel lug nuts are torqued and 2 are gun tight what will happen?
Oct 23, 2023 at 4:15 AM
  • 55,711 POSTS
If the wheel lug nuts are not tightened correctly it can cause the brake rotor or rim to warp and cause a vibration in the steering wheel, also it can cause one or more of the lug nuts to come off while driving or the wheel stud can break. Are you having a problem?
Oct 23, 2023 at 5:03 AM
