My passenger side wheel has been making a weird noise. It is only when I push on the gas and once I got past 40 mph it stops.
Oct 12, 2016 at 2:08 AM
HMAC300
✓Experienced Mechanic
drive in a left hand circle and if noise increases it may be a wheel bearing. then drive in a right hand circle if noise reduces that will verify it. it could also be an axle shaft so it may do the same.
