Car makes a tapping or clack clack clack only on turning drivers side
115,000 MILES • 4 CYL • 2WD • AUTOMATIC
TOYPACIFIC
  • 159 POSTS
When driving straight car sounds fine but when turning left or right there is a tapping noise on the drivers side. Once you make your wheel straight it will go away. I was thinking wheel bearing or perhaps CV outer shaft.. what's your take on it?
Just to recap, the car makes a tapping or clack clack clack only on turning drivers side
Aug 9, 2020 at 4:22 PM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
It sounds like the most likely culprit is the CV joint, I would advise taking it to a parking lot that has a reasonable amount of clear space and turning the wheel almost to lock and driving in both directions, if it clicks doing this you can be reasonably sure that replacing the axle will cure the problem. Please keep us up to date on your progress and thank you for using 2CarPros!
Aug 9, 2020 at 9:00 PM
Good morning,
This sounds like the outer CV joint itself.
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
The axle shaft will have to be replaced.. Once it starts making noise, there is nothing you can do to get rid of the noise.
https://www.2carpros.com/articles/replace-cv-axle
PROCEDURE
REMOVE FRONT WHEELS
REMOVE ENGINE UNDER COVER LH
REMOVE ENGINE UNDER COVER RH
DRAIN CONTINUOUSLY VARIABLE TRANSAXLE FLUID (for CVT)
Click here [ K313 (CVT): FRONT DIFFERENTIAL OIL SEAL: REPLACEMENT+ ]
DRAIN AUTOMATIC TRANSAXLE FLUID (for Automatic Transaxle)
Click here [ U341E (AUTOMATIC TRANSMISSION / TRANSAXLE): VALVE BODY ASSEMBLY: REMOVAL+ ]
DRAIN MANUAL TRANSAXLE OIL (for Manual Transaxle)
Click here [ EC65 MANUAL TRANSMISSION / TRANSAXLE: MANUAL TRANSAXLE OIL: REPLACEMENT+ ]
REMOVE FRONT AXLE SHAFT NUT
Using SST and a hammer, release the staked part of the front axle shaft nut.
SST : 09930-00010
NOTICE:
Loosen the staked part of the front axle shaft nut completely, otherwise the threads of the drive shaft may be damaged.
While applying the brakes, remove the front axle shaft nut.
SEPARATE FRONT SPEED SENSOR
Click here [ AXLE AND DIFFERENTIAL: FRONT AXLE HUB: REMOVAL+ ]
SEPARATE TIE ROD END SUB-ASSEMBLY
Click here [ STEERING GEAR / LINKAGE: STEERING GEAR: REMOVAL+ ]
SEPARATE FRONT STABILIZER LINK ASSEMBLY
Click here [ FRONT SUSPENSION: FRONT SHOCK ABSORBER: REMOVAL+ ]
SEPARATE FRONT LOWER NO. 1 SUSPENSION ARM SUB-ASSEMBLY
SEPARATE FRONT DRIVE SHAFT ASSEMBLY
REMOVE FRONT DRIVE SHAFT ASSEMBLY LH
Using SST, remove the front drive shaft assembly LH.
Aug 9, 2020 at 9:03 PM
Did you respond? I got an email but nothing came through.
Aug 9, 2020 at 10:18 PM
Still did not come through.
Try sending to my email. Roybelding@gmail.com
Aug 9, 2020 at 10:21 PM
