Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercedes Benz
300d
Engine
Symptoms
Runs Hot
car is running hot
1981 MERCEDES BENZ 300D
125,000 MILES
ERROLC
MEMBER
1 POST
I have changed the fan clutch, thermostat, water pump, and I have no water leaks. The car is still running hot.What could be the cause?
Jun 4, 2017 at 12:56 AM
JIS001
Experienced Mechanic
Make sure you have properly bleed off the cooling system. Any air pockets will cause it to over heat.
Jun 4, 2017 at 11:22 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
