I have changed the fan clutch, thermostat, water pump, and I have no water leaks. The car is still running hot.What could be the cause?
Jun 4, 2017 at 12:56 AM
JIS001
✓Experienced Mechanic
Make sure you have properly bleed off the cooling system. Any air pockets will cause it to over heat.
Jun 4, 2017 at 11:22 AM
