code P0705
145,000 MILES
JUANLOVEU
What does code P0705 mean? it comes up.
Jan 30, 2017 at 12:51 PM
HMAC300
  • 48,601 POSTS
705 is the digital range sensor which you will know as the neutral safety switch. check connections and be careful when you disconnect things.
Jan 30, 2017 at 10:13 PM
STEVE W.
  • 15,410 POSTS
P0705 - Transmission Range Sensor Circuit Malfunction. Can mean the sensor itself is bad or that the wiring going to it has a problem.
Digital TR sensor circuits, indicating an invalid pattern in TR_D.
Condition caused by a short to ground or an open in TR4, TR3A, TR2 and/or TR1 circuits.
This DTC cannot be set by an incorrectly adjusted digital TR sensor.
Jan 30, 2017 at 11:49 PM
