Codes p2282 and 7ep8
160,124 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
SAULIUS TRUMPIS
What is the problem?
Jun 23, 2019 at 10:06 PM
  • 110,248 POSTS
Welcome to 2CarPros.
With the code you indicated, it seems there is an engine vacuum leak between the throttle body and in the engine. With that, you need to check all vacuum hoses to the intake manifold as well as check the intake gasket and throttle body for leaks.
Here is a link that explains how to check for an engine vacuum leak:
Do this and let me know the results.
Jun 24, 2019 at 1:28 PM
