engine slows down when going up hills
182,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
JOHNNY MCCORMICK
My truck wants to bulge down when I go up hill. My truck starts up just fine. I just changed the spark plugs and put a new fuel filter in it yesterday. It still bulges down when you drive it up hill.
Mar 8, 2018 at 1:17 AM
Good afternoon.
Two possibilities:
1. Low fuel pressure. if you have low pressure from a weak pump, it will cause this. you can test the pressure with a gauge. if you do not have one you can rent one at a parts store.
2. clogged catalytic converter. this is more of a common failure. if the exhaust becomes clogged, it cannot breathe and will cause reduced power under load. there is back pressure gauge that you can test the back pressure. you would remove an O2 sensor and insert the gauge and test the reading you can also test by unbolting the exhaust pipes at the exhaust manifolds and take it for a ride.
Mar 8, 2018 at 3:30 AM
