What years are interchangeable for doors and fenders?
200,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
XAVALADEDZX
Passenger side door and fender where in an accident and need to be replaced.
Sep 3, 2018 at 7:10 AM
STEVE W.
  • 15,401 POSTS
2004 and 2005 are the only two years that interchange on the fenders. 2003 - 2005 on the door. Please let us know if you need anything else to get the problem fixed.
Sep 3, 2018 at 8:56 AM
SKISLOPE
Hit a deer with my 2000 Ford Ranger and it smashed up the grill, left front fender, and hood. Have a 1994 Ranger and would like to know if the body parts from the 1994 will fit on the 2000
Sep 24, 2020 at 3:36 AM (Merged)
nope, all different parts.
you can secure a front clip at a junk yard. why dont you try to trade your 94 for all the body parts you need for the 2000??
SKISLOPE
Could you replace all of the 2000 ranger front body parts with the 1994, instead of just a fender,ect?
it is possible but will take a lot of re structuring.
SKISLOPE
Thank you for your help.
LYTLE123
I have a ford ranger 1994 and the front got hit and it needs new fenders and hood what other years of rangers will fit?
CARADIODOC
  • 34,413 POSTS
Visit any salvage yard or your library and ask for a "Hollander Guide". Those list every part and give them a code number, then you look that number up in the back of the book and it will list every model and year that uses that same part.
If you want to take the time, you can also use sites like the Rock Auto site and look up the fender's part number for various years. If you find the same number for two different years, you know they're the same, but when the numbers are different, you can't always be sure unless you look through all the different suppliers. One supplier might list two different numbers. The fenders could be the same, but one comes with brackets already welded on or side marker lights cut out already, and things like that. This works best when you already have a specific parts truck in mind. It takes a long time to go through all the years, and then you have to go out and find one of those years in the salvage yard.
