What wiring harness do I need?
109,200 MILES • 4 CYL • AUTOMATIC
DUKERZ03
Mice chewed the wires that connect.to the coil pack. I ordered part number 27350-2b000 ignition coil wire harness. I was told it is not the correct.part. every time I look it up I find the same part. It visually looks right but I believe the big connector is what's not correct. I'm not sure what the harness I need is.
Apr 12, 2025 at 6:09 AM
  • 55,658 POSTS
The part number 27350-2B000 is the ignition coil itself, so that might be why. You may need repair pigtail 91401-2E000 so this is what I would look for, can you just repair the harness can you upload images of the damage so I can see?
Apr 13, 2025 at 4:40 AM
