HI. I'm trying to find what wires I need to connect to from the TIPM that will allow me to bypass the relay. Fuse M22 is before the relay, so I can't tell if I have a bad relay, or bad pump. I have the color of the wires to the pump, but I'm missing the color of a wire from the TIPM that I can use to energize the relay that only comes on at key on. Would anyone have a wiring diagram that I can see to help me choose the wires I should use? Thanks for your time in this matter.
Truck listed above is a 1500.
Oct 5, 2020 at 5:39 AM
