need to change my rear main seal
115,854 MILES • 2.2L • 4 CYL • AWD • AUTOMATIC
ASHLEI BERSANE
I need to change my rear main seal and need to know everything i will need to get the job done. If you could please help me with a detailed list i would really appreciate it thanks.
Jun 9, 2017 at 3:25 AM
  • 55,721 POSTS
To change the rear main seal you will need to remove the transmission. Here is a guide that will show you how to jack the car up to get started. Disconnect the battery first
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Here is a guide that will give you an idea on what you are in for when doing the job.
https://www.2carpros.com/articles/transmission-replacement-removal-manual
and
https://www.2carpros.com/articles/crankshaft-main-seal-replacement-rear
Here are some diagrams (below) to show you what it will be like on your car.
Cheers, Ken
Jun 12, 2017 at 7:24 AM
